CF 105 Avro Arrow 1
dik
CA
New article... the beginning of Canada's decline...
I truly believe that the USAF/GD F-106A/B Darts were the equal-to/superior-to the CF-105 Arrow... as an interceptor... at about the very same time.
Discosure... Yes I supported the 106 in the early-to-mid 1980s at Kelly AFB [SA-ALC]. Then it was summarily retired [except for research]. What an elegant design... to be replaced by the MDC F-15s and the GD F-16s...
For this reason the CF-105 was simply 'not good enough'. What really bothers me is how secretive, stealthy and cold the Canadian Govt was in shutting-down the program and destroying the CF-105 assets and technical info. With rare exceptions... little is known to exist of the CF-105.. not even a museum/display aircraft, as I recall.
At least the US places it's 1-2-3-off test aircraft/data in museums and/or on displays. For instance the ONLY YA-10B 2-seater is on display at Edwards AFB... along with the prototype T-46's. Too bad that The USAF decided against any production A-10B Tubs. I was really impressed when I saw the prototype [being modified from an early pre-production flight-test airframe] at Fairchild Republic in the Mid 1980s. At that time it was a 'low-key hush-hush' demo-program primarily funded by FRC.
Regards, Wil Taylor
o Trust - But Verify!
o For those who believe, no proof is required; for those who cannot believe, no proof is possible. [variation, Stuart Chase]
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion", HBA forum]
o Only fools and charlatans know everything and understand everything." -Anton Chekhov
Dik,
Thank you for the link to the article. I have been meaning to read it but only got as far as a brief summary.
Wil,
I could nitpick by saying that a comparison isn't fair between a twin-engine interceptor and a single, or one that entered service and the other didn't, meaning the performance specs of the F-106 are well known and the CF-105 are uncertain.
There's a bit too much romance and nostalgia around the Arrow for many aviation fans (in Canada at least) to be objective about it. It's the first plane whose specifications I memorized as a kid. When the standard in my mind against which all of the other planes are compared is a plane that never really was... well... I'm going to love the Arrow forever no matter what anyone says.
One thing that always stands out is that the Arrow was HUGE. It carries twice as much armament as the Dart, but burns twice the fuel, so which plane is the best bang for the buck?
Look at the present tense sneaking into my sentences - "was", eh?
I'm not certain, but I understand that at the time, it was quite a formidable interceptor with many new features in aircraft design.
What's really disappointing and really suspect, the government decided to destroy all records of it... and only a few items remain... that includes drawings, design, etc.
In addition... to reiterate, it was the beginning of Canada's decline. “that f------ prick in Ottawa” people didn't talk like that back then... Dief must have been exceptional.
"The advert for Avro Aircraft celebrating the “first 50 years of powered flight in Canada 1909–1959” had only just been printed when on “Black Friday”, 20 February 1959, the loudspeaker of the Avro Aircraft factory on the outskirts of Toronto crackled to life. Thousands of workers heard the company president announce “that f------ prick in Ottawa” (the newly elected Canadian prime minister John Diefenbaker) had cancelled the entire Arrow programme. Later that day, 14,500 skilled men and women lost their jobs. Many of these engineers joined the brain-drain to the United States. The "Avro group" of 32 engineers playing critical roles in Nasa's Apollo programme, which – ironically – beat the Soviets in the race to land a man on the moon."
...and another article... not too shabby for an aircraft at the time.
"The CF-105 was designed as a twin-engine, long-range, high-wing delta, all-weather supersonic interceptor. Its key mission in war time was to prevent attack from incoming enemy aircraft from across the North Pole and south into Canadian skies and into the United States. Likewise, it was designed to prevent the intrusion of North American airspace by high flying enemy reconnaissance aircraft similar to the U-2. In peacetime, it would expose any violations of Canadian airspace, while bringing human judgement to bear, a role that could not be fulfilled by missiles, which once launched were unable to be recalled. The aircraft was built to fly at Mach 2 and reach altitudes of 60,000 feet. In flight tests, using underpowered engines, it climbed to 58,000 feet and topped out at Mach 1.9 in level flight and Mach 1.95 in a slight dive. With its proper Iroquois engines, it was said it would break all speed records."
The 105 and the TSR-2 are somewhat in the same basket, they were just too far ahead of what was mature technology for the budget available, a few of years later they would have likely been fine. Just for example look at the size of the avionics on the TRS-2, ten years later and it would have been micro chips instead of valves.
Edit that should have been "look at the size of the avionics bay on the TRS-2" that thing is massive.
the Arrow is like the girl friend you never met ... mostly imagined and flawless.
At least we met the TSR2 ... and liked what we saw, but then facelifts can be expensive.
Undeniably, both projects cost far more then either government could afford. Both failed to achieve the political dimension of the project.
As noted above, both would have been outpaced by technical advancements.
I wonder if they'd been more successful if they had a US partner ... but that's not what we did back then.
When the Arrow program was cancelled, many of those engineers went south to the US. The space race had started and NASA was being organized. These engineers contributed to the Mercury, Gemini, and Saturn programs.
Funny... at the time, it was thought the project was scuttled because of American pressure on our government.
Perhaps contributing to all of this mess was the [still top secret, in design] Lockheed A-12 [Oxcart] and YF-12A... leading to the SR-71???
From my perspective, the SR-71 was truly successful, primarily due to [3] factors: (A) Lockheed Skunk Works [designers/builders]; (B) the [best-of-the-best] air/ground-crews; and (C) high reliability engines.
As with MOST of these extreme-high-speed aircraft, the engines have always been the 'long-pole in the tent'... lagging way behind the airframes and systems.
RE the engines: they were able to throttle full-up for climb/re-fuel/climb-to-mission cruise... then throttle back-down for descent/re-fuel... then throttle-back-up for climb-to mission-cruise... then throttle back-down for descent/re-fuel... etc... several times per mission. In this is a fairly abusive regimen for the engines, few catastrophic failures ever occurred that were 'non-recoverable'. Thank God.
As I understand it, the MiG 25 FoxBat was able to fly close to SR-71 speeds for a few minutes at a time... then the engines had to be throttled-back to prevent inevitable catastrophic failures.... and usually had to be replaced after every mission.
Regards, Wil Taylor
RB1957: "As noted above, both would have been outpaced by technical advancements."
Politicians make this mistake all the time, then and now. Like most people they are very bad at seeing the future.
Even the supposedly smart analysts who wrote the 1958 paper that DIK linked to couldn't see the future well enough to realize that strategic bombers would be a long-term threat that Canada needed interceptors for, and that intercepting an aircraft with a crappy Bomarc won't work.
Every article of war will be outpaced by the adversary, just give them time.
Your own engineers may obsolete your own technology when novel inventions revolutionize how things are done (eg. transistors).
There is no competition if there is no obsolescence.
Consider...
There will be a day when the F-35 is outperformed by a better aircraft.
(And beware that better aircraft might be made in China sooner than you think.)
Concur Spar... I was in Grade school when it was cancelled... don't think I was even a teenager... and was heartbroken about the decision. Knew little about aircraft other than this was an 'exceptional' one...
"Funny... at the time, it was thought the project was scuttled because of American pressure on our government."
of course it was. The yanks (forgive me Will) were acting like bullies. They killed off the Arrow (offered Canada Bomarcs), and effectively killed the TSR2 (ok, contributed to the death of the TSR2) by offering Australia the wonderful F111. I think they offered the Aardvark to the UK but they went with F4s (after they reengined them ... for lower performance as I recall). They wanted to dominate the military aerospace, instead of thinking ... "hey, maybe these guys have some good ideas. Maybe we should work together ?" ... nah, we'll steal their lunch money, and drink their milkshakes. Yes, the engineers contributed to other programs, but that was an unintended consequence.
WKTaylor,
In concept, the Avro Arrow was very much closer to the McDonnell Douglas F4 Phantom. It was a big aircraft with two big engines, a pilot and a radar operator. Unlike the Phantom, the radar operator is hard to see because he has only two tiny windows. In Vietnam, when radar operators were not radar operating, they often kept a watch out to the rear to see what mischief the Vietnamese air force was getting into. The Arrow was a typical fifties fighter aircraft that was going to detect the enemy on its radar, someone would push a button, and a missile would be launched. Judging from FlightGear's model, the Arrow pilot has no view to the rear, or up above.
Typhoon and Tempest at War by Arthur Reed & Roland Beamont is a fun read. In the late thirties, it was assumed that 400mph aircraft were too fast to get into dogfights, so they did not need a good view out of the cockpit. Writing in the mid-seventies, Beamont remarked on how air forces now were "buying simple, unsophisticated fighters with one overriding attribute, an ability to hold their own in dogfights." Now look at any photo of an F35.
JHG
The sad part is that the Arrow was the apex of Canada... been downhill since... [sad]
WKTaylor,
I forgot to mention that the Avro Arrow McDonnell Douglas F4 makes sense for the Canadian military. Canada is a very large place with a low population. Relatively few aircraft must fly long distances to carry out any sort of mission. If you are a crowded country, your aircraft can be smaller and shorter ranged.
I don't know if Phantoms ever were considered for the Royal Canadian Air Force (RCAF). It might have been politically messy.
The factoid we keep hearing about the Arrow is that it did Mach[ ]2+, and that modern fighters could not catch it. Actually, a bunch of late fifties aircraft exceeded Mach[ ]2. Turbojet technology has plateaued, and tactical experience has showed us the importance of things other than top speed.
JHG
What I find fascinating is that there were no "experts" at the time. Supersonic flight was new and everyone was winging it. Without experts the developed designs that will never be succeeded.
Interesting that the CF-105 engine intakes appear to exactly match those on the F4.
TugboatEng,
They were solving the exact same problem. Convergent technology has to happen sooner or later.
JHG
Or maybe the expert who designed the Arrow inlet was hired by McD and designed the F4 inlet.
That was my thought. That was a really special generation of engineers. Their problem solving was unique.
