Hydraulic Power Steering Racks differences?
I'd like to add a GM power steering rack on '88 Lotus Esprit turbo (2900 lb gross weight).
I'm looking for a suitable part which has similar((+/-) attachment spread/points to the chassis.
I found several potential donors, but have difficult time to find a right attachment spread.
One of the candidates is a Silverado pick-up truck (6000 lb GW), which seems to fit well.
I'd like to confirm,
that perhaps a truck stock rack may be "too strong" (different valving)for a passenger car.
Should I rather look for a Regal of Bonneville part, instead?
Thank you
Thank you
RE: Hydraulic Power Steering Racks differences?
The amount of boost in an HPAS is governed by the system pressure, the piston diameter, the C factor of the pinion to rack, the valving of the T bar, and the stiffness of the T bar. A truck rack is likely to have a big diameter, low C factor, and different valving and T bar stiffness to a car's rack.
Cheers
Greg Locock
My van has pretty lousy steering feel, too, but I don't drive it hard. And, being front wheel drive with lots of built-in understeer, there's not much need for having to catch a slide.
This can then be used when parking. I'd be wary of how much friction it adds when running unassisted.
Cheers
Greg Locock
Finally you need a pump that's built for the job, too. If it were up to me, I'd pull parts from a BMW 5 Series and stuff them in. [The lines with tuned dampers, too].
After investigating hundreds of them, I selected a potential donor: 94 Buick Regal rack.
It has the most acceptable attaching mounts (slight rework required), and is comparable dimensionally. Also it has the same pitch and range and uses the same rod ends as my old manual part. All specs can be seen on Rockaut0 website when you click on the blue "Info" button next to the part. Terrific research tool.
