FEMAP datasurfaces shutdown
Xprivate
Aerospace
May 26, 2023
55
Hi Everyone , question for FEMAP users. Has anyone experienced a sudden shutdown in the FEMAP window while using datasurfaces to apply load on your elements ? . If so how did you overcome this and how did u still apply the loads on the elements using data surfaces ?
Thank you in advance
What type of data surface were you using? About how many data points did you have in it?
Hi TG_eng , i was using pressure mapping on elements . around 55700 elemnts were mapped with pressure from another similar model
