Desulfurization
BZLAM21
Petroleum
Aug 12, 2020
61
Hello all,
Can some one help me to calculate the quantity of hydrogen necessary for the desulfurization of natural gas knowing that :
gas flow=217 kg/h
Total sulphur content (ppmw)=40
Required toal sulphur (ppmw)=1
Is there a good practice wich help to minimise the consumption of H2 knowing that there is a shortage of H2.
NB:purpose of desulfurization is to prepare the feed for steam reforming.
Best regards.
Typically, desulphurisation of trace amounts of H2S in nat gas (in pretreatment for steam reforming) is done by passing the gas over a bed of Girdler catalyst whose active component is ZnO. The bed is kept hot to enable a fast reaction. No H2 required.
ZnO + H2S = ZnS + H2O
Yes i agree this is the second step but i was talking about total sulphur eg:
CH3SH+H2=CH4+H2S
H2S++ZNO=ZNS+H2O
So first equation need H2 .
Kind regards.
Calcs tell me the quantity of H2 required, (for 217 kg/hr of nat gas with 40ppmw of sulphur as CH3-SH) for stoichiometric completion of reaction 1 is 5.4e-4 kg/hr
Adding 100 % excess H2 to ensure completion of reaction, H2 required is 0.0011kg/hr or 0.013Sm3/hr.
Are you using some catalyst to speed up reaction 1 ?
Thank you for response georgeverghese.
Yes we will use a catalyst.
Could you plesase explain hiw did you calculate the quantity of H2.
Kind regards.
Total sulphur in feed gas = 40e-6 x 217 = 8.68e-3kg/hr, which is attributable to the sulphur in CH3SH - sulphur atomic weight = 32
CH3SH mol wt = 48
Quantity of CH3SH in feedgas = (8.68e-3/32) x 48 = 0.013kg/hr
So, from the reaction, 48kg of CH3SH reacts with 2kg of H2
H2 required for stoichiometric completion of reaction 1 = (0.013/48) x 2 = 5.4e-4kg/hr
Add 100% excess H2 to ensure completion of reaction at sufficient speed = 5.4e-4 x 2 = 0.0011kg/hr
1kgmole = 23.645sm3, so this is = 0.0011 x 23.645 = 0.013Sm3/hr
From this article, with Ni-Mo catalyst for reaction 1, it seems 100% excess H2 is adequate
