FEA beginner help
aldumoul
65
Hello, haven’t used FEA in quite some time.
Not sure how to interpret the results. I found in my hand calc, the max stress the broached shaft will see is 2830 psi. And the max/yield to be 4026 psi. Which matches the Von Mises result. The analysis is for torsion in the cross section of the id/keyway. How should I interpret the von mises and principal results?
 https://files.engineering.com/getfile.aspx?folder=fc25b563-d2e1-40c8-83cc-0e24faa886b4&file=D45528-XX_FOR_FEA_8.28.23.ipt_Stress_Analysis_Report_8_28_2023.pdf
So your question is what do those quantities mean ? You will need some theory to understand this. It's typically discussed in mechanics of materials textbooks, in chapters about analysis of stress but I can also recommend "Building Better Products with Finite Element Analysis" by V. Adams. In that book you will find a short description related to practical application in FEA.
Hi aldomoul,
As FEA way alluded to you must have a thorough grasp of basic mechanics of materials. Also read up on basic elasticity theory.
You must be able to do rough "sanity" checks on your results using hand calculations on a simplified representation of the part in question.
Another essential check is the displacements of the part or structure: do they make physical sense? Are the boundary conditions correct?
This way of working requires experience but is the only way.
All the best.
Andries
First, please change your pdf, so that the header of each pic is on the same page as the pic !
Linear FEA ? if so, pretty meaningless if you're trying to detect the stress concentration in the keyway.
Element stresses ... also pretty meaningless if you're trying to detect the Kt; use nodal stress.
Many shafts/keyways are critical in fatigue.
