Seeking Help with Defining VUSDFLD Subroutine from USDFLD in ABAQUS
DemonMelon
Student
Aug 10, 2023
I am currently facing a technical challenge regarding the transition from static analysis in ABAQUS Standard to explicit dynamics analysis.
Specifically, I have been using the USDFLD subroutine to define a material with varying elastic modulus and Poisson's ratio based on the thickness direction of a plate.
However, I am now required to perform an explicit dynamics analysis with the same material properties, and I am unsure about how to define the VUSDFLD subroutine accordingly.
Can anyone help my problem?
Thanks.
Code:
SUBROUTINE USDFLD(FIELD,STATEV,PNEWDT,DIRECT,T,CELENT,
1 TIME,DTIME,CMNAME,ORNAME,NFIELD,NSTATV,NOEL,NPT,LAYER,
2 KSPT,KSTEP,KINC,NDI,NSHR,COORD,JMAC,JMATYP,MATLAYO,LACCFLA)
C
INCLUDE 'ABA_PARAM.INC'
C
CHARACTER*80 CMNAME,ORNAME
CHARACTER*3 FLGRAY(15)
DIMENSION FIELD(NFIELD),STATEV(NSTATV),DIRECT(3,3),
1 T(3,3),TIME(2)
DIMENSION ARRAY(15),JARRAY(15),JMAC(*),JMATYP(*),COORD(*)
C-----------------------------------------------------------------------
C user coding to define FIELD and, if necessary, STATEV and PNEWDT
C CENTER OF COORDINATE SYSTEM
X0=0.0
Y0=0.0
Z0=0.0
C READ X,Y,Z COORDINATES OF THE NODE
X=COORD(1)
Y=COORD(2)
Z=COORD(3)
C CALCULATE YOUNG`S MODULUS IN CYLINDRICAL COORDINATES
E=SQRT((Z-Z0)**2+(Y-Y0)**2)
C DEFINE DEPENDENT VARIABLE E(X,Y)
FIELD(1)=E
C SAVE E IN STATEV(1)
STATEV(1)= -4112*E**3 + 1.727e+05*E**2 - 2.397e+06*E + 1.101e+07
C------------------ END OF USER CODE ---------------------------------
RETURN
END
Above is the usdfld subroutine.
