Vibration loosening of bolts/nuts of B16.5 or ASME VIII bolted connections 1
jennin77
IT
Does the ASME address anyhow the loosening failure risk of bolted joints under vibration?
I do not find anything written in the entire ASME collection.
Thanks!!!
This is typical post-construction stuff, whereas design code are for new construction.
You might find something in one of the ASME PCC standards, but Im not sure. Or ASME OM, which has a section on vibration for piping systems.
Huub
- You never get what you expect, you only get what you inspect.
