Pass the root of a resolved equation to a new variable
BillHugh
Aerospace
GB
After solving an equation and I have found a root of 8.83 for unknown D. Now how can I pass the value of 8.83 to a new variable WW automatically without typing WW:=8.83. See below for part of my worksheet.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1690968070/tips/Photo_cn8mzh.docx[/url]
After resolving this equation, I know D=8.83, but how can I carry on using this found value D of 8.83 since if I type D:=, then I have no return, this is to say variable WW is not defined.
Please can you help?
Thank you very much in advance.
Bill
Perhaps you should identify the application that you're using.
Providing a Mathcad file directly would help, assuming that's what it is.
You should be able to assign your solution directly to D for use in the last equation
Student homework should be posted only in the student forum
TTFN (ta ta for now)
Thanks for all the responses received. I found a way to carry on using the resolved root of the equations.
