kesternich test
Joanne Eng
Bioengineer
SG
Anyone know what is the kesternich test? what does it do?
I'd not heard of it... but, from wiki...
Kesternich testing is a common name for sulfur dioxide testing. There are several test methods available, including DIN 50018, ISO 3231, and ASTM G87, which are some of the more common methods. Industrial objects (especially metal objects subject to corrosion) often are rated in Kesternich cycles (a measure of resistance to corrosion).
Did you not do any searching online?
Your questions are becoming a little bit simple and you don't respond or provide anything more than one line of text.
This is not the purpose of this site.
