Contact US
Welding Symbol Help
Welding Symbol Help
RE: Welding Symbol Help
From what I see, just a regular Fillet. you just need to decide inside, outside or both.
Google weld symbol chart.
Meant to answer earlier and forgot.
Anyway, if those corners touch, then just a fillet inside and fillet outside. This is done all the time with thicker plate.
If the corners don't touch, I'm not so sure. It might help to show us what the weld actually would look like.
The weld symbols are intended to communicate how to weld that, but sometimes, you may need to write out a paragraph or draw a picture instead of, or in addition to, the weld symbol.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
