lucky-guesser
Industrial
This is perhaps not the correct category for this, but I don't exactly know how to classify this as there are several issues and I know it will be seen here...
We produce water storage tanks made from galvanized steel, which is common practice in our industry but it does rust/corrode/leak eventually. We are hoping to get more life out of these tanks by spraying on either some sort of sealant or corrosive barrier to the entire inside surface of the tanks. One of my coworkers did a little testing a couple years ago related to coatings, but nothing extensive and with a different goal in mind so there's not a whole lot I can take from it.
Question to you all is, is there a certain coating that you would recommend, preferably one that you have personal experience bonding to galv. We would potentially be using hundreds to a few thousand gallons a year.
Since galvanized is the bane of my existence, question 2 is what did you do for prep work? One coating company recommended shot peening for their coating but another company said that their coating requires a more abrasive blasting to rough up the surface more, so I think the prep work is also pretty coating specific. What do you use to quickly/efficiently clean the surface between blasting and coating?
