Can any one share the photograph to 1
Anans
Industrial
IN
Can any one share the photograph to understand how the baseframe is mounted over the AVM. (What is loaded height, is there any separate plate required to welded underneath the baseplate to support / connect with AVM)
AVM?
This doesn't make any sense to me...
AVM (ANTI VIBRATION MOUNT) FPSO PROJECTS
THREE POINT MOUNTING BASEFRAME SKIR
Since I am new to this. How can I replies to the comments. Can anyone guide me.
You either use the quotes icon and then reply.
Or just write @ctopher - Thanks for the tip
you can't reply direct to each one here, it's just a series of sequential posts. That works for this site to avoid multiple sub threads developing.
Or just reply in the next post providing the required information...
@LittleInch thank you for your response.
@ctopher thank you for your response. I am looking for sample photograph of AVM mounting with base frame. This baseframe is used in FPSO application. AVM - Anti VIBRATION MOUNT (three point mount)
Basically this is pump skid.
Any other details required please let me know..
@littleinch
I am the designer on this project.
Thank you very much for sharing the details.
Let me check.
Looks pretty much to me like they all use a three point mounting system and stress / design the baseplate to account for connection via three point loads.
