Hi everyone .
to understand what it is I thought the best thing is to attach a link . in link 502574 it says what I want to do.
if, on the other hand, you don't want to read, I'll explain briefly and in simple terms that it is a direct current electromagnet with a ring to close the return path of the magnetic field.
I stopped in front of a problem.
I have to create a cylinder starting from a package of laser cut laminations and then I have to stack them together, in the end they have to be turned on the lathe.
I don't have clear ideas on how to keep them together, I'd like to know how they do it in the industry that builds electric motors.
for example, I remember that years ago I disassembled an engine and the rotor was made up of a pack of very thin laminations joined together but I didn't understand how the job was done.
