Contact US
Rated temperature for magnets
How is the rated temperature for magnets established?
Clyde Hancock
Design & analysis of electric motors and generators
www.motorconsultants.com
RE: Rated temperature for magnets
Two methods.
One is to run full demag curves at various temps.
This takes time and money but it gives very reliable information.
You then decide how much reduction in properties you will consider acceptable.
The other method is to build small fixtures that place the magnets at various operating conditions (demag) and then expose these to different temperatures.
Or of could you could just copy with other people publish and assume that it is good for your material.
Thanks, I understand but I am curious as to how the published data is determined. In other words, what does he magnet vendor due to establish the values they publish?
Clyde Hancock
The rated temperature is oftentimes called maximum operating temperature and it is more of a marketing concept. I don't like it very much, but it has gained widespread acceptance amongst laypeople.
That said, when the concept was introduced it was defined as the temperature when a magnet with a B/H ratio of 1.0 would weaken by a certain percentage. As time passed, manufacturers 'stretched' these criteria and nowadays most of the industry has settled with the data you see on most websites.
Hope that helps.
-Mike
Thanks Mike, that's what I was looking for.
Clyde Hancock
If you hunt some you can find temperature coefficients for Br, Hc, Hci, and EP.
Then knowing the characteristics of your application you can estimate the drop in field with temperature.
Most devices will stop working long before you ruin the magnet, unless you are using Neo.
For fun we built a thermometer using NdFeB magnets, their output varies that much.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
