I need to make a metal plate at the size of 76mm*34mm. it will have around 70KG on it (the stress source is about a 3cm circle. the metal piece has 2 supports 42 mm apart(the load is in the middle of them).
I need to choose the metal type and thickness. I would like it to be as cheap of metal as possible and as thin as possible (hopefully a common metal)
I'm a chemist so I'm not very proficient in the matter.
thank you.
thank you.
