Jun 9, 2023 #1 KH-001 Petroleum Joined Apr 1, 2022 Messages 2 Location DZ hi please could some one give me the standard for A320 L7 Bolt Torque Chart and A193 B7..... thanks
Jun 9, 2023 1 #2 SnTMan Mechanical Joined Jan 22, 2005 Messages 6,858 Location US KH-001, you tried Google? Regards, Mike The problem with sloppy work is that the supply FAR EXCEEDS the demand Upvote 0 Downvote
Jun 9, 2023 #3 TGS4 Mechanical Joined Nov 8, 2004 Messages 3,986 Location CA Torque values depend on the choice of a nut factor, which is highly dependent on the lubricant chosen. Use all published torque charts with caution, understanding the assumptions of the nut factor embedded in the table. Upvote 0 Downvote
Jun 10, 2023 #4 r6155 Mechanical Joined Jan 12, 2010 Messages 3,004 Location AR Avoid torque. Use bolt elongation. Regards Upvote 0 Downvote
Jul 3, 2023 #5 nashki Mechanical Joined Jun 5, 2023 Messages 25 Location SG API 6A could be a reference It will depends on the coating of the bolt and nut Upvote 0 Downvote
