ANSYS Memory Option Help
tsam2
1
I'm doing an analysis and am getting the following output:
***** ANSYS SOLUTION ROUTINE *****
USE THE FULL NEWTON-RAPHSON OPTION FOR ALL DEGREES OF FREEDOM
WITH UNSYMMETRIC SOLVER
AND USE THE DEFAULT ADAPTIVE DESCENT OPTION
USE 1000 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL DEGREES OF FREEDOM
FOR AUTOMATIC TIME STEPPING:
USE 50000 SUBSTEPS AS A MAXIMUM
USE 500 SUBSTEPS AS A MINIMUM
WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF -10
FOR ALL APPLICABLE ENTITIES
USE A MAXIMUM OF 100 EQUILIBRIUM ITERATIONS EACH SUBSTEP
*** WARNING *** CP = 671.656 TIME= 11:16:45
The MINREF field of the CNVTOL command has been assigned a default
value of 1.0 for convergence on f. Check results carefully.
CONVERGENCE ON F BASED ON THE NORM OF THE N-R LOAD
WITH A TOLERANCE OF 0.1500E-01 AND A MINIMUM REFERENCE VALUE OF 1.000
USING THE L1 NORM (CHECK THE ABSOLUTE VALUE SUM)
CONVERGENCE ON U BASED ON THE NORM OF THE TOTAL
WITH A TOLERANCE OF 0.1000 AND A MINIMUM REFERENCE VALUE OF 0.000
USING THE INFINITE NORM (CHECK EACH DEGREE OF FREEDOM SEPARATELY)
*** NOTE *** CP = 671.703 TIME= 11:16:45
Even though no prior convergence specification exists for removal. The
CNVTOL command is still executed for removal of label ROT.
CONVERGENCE BASED ON ROT IS REMOVED
CNVTOL command is still executed for removal of label M.
CONVERGENCE BASED ON M IS REMOVED
DO NOT USE PREDICTOR METHOD FOR ALL DEGREES OF FREEDOM
USE A LINE SEARCH FOR ALL DEGREES OF FREEDOM
KEY TO TERMINATE RUN IF NO CONVERGENCE= 2
DEGREE OF FREEDOM (DISPLACEMENT) LIMIT= 0.0000
CUMULATIVE ITERATION LIMIT= 0
ELAPSED TIME LIMIT (SEC)= 0.0000 ( 0 HOURS 0 MIN)
CPU TIME LIMIT (SEC)= 0.0000 ( 0 HOURS 0 MIN)
NLDIAG: Nonlinear diagnostics NRRE option is set to ON.
The number of files/iterations to be saved for NRRE nonlinear diagnostics is 4
DSPOPTION: USE IN-CORE MEMORY ALLOCATION LOGIC FOR DISTRIBUTED SPARSE DIRECT SOLVER
DSPOPTION: USER SET DISTRIBUTED SPARSE SOLVER PERFORMANCE SUMMARY
TITLE=
Case 1, Tension
SELECT COMPONENT N_LOAD_COLUMN
*GET N_COUNT_ FROM NODE ITEM=COUN VALUE= 92.0000000
SPECIFIED NODAL LOAD FY FOR SELECTED NODES 1 TO 88312 BY 1
REAL= 128396.739 IMAG= 0.00000000
SPECIFIED CONSTRAINT UX FOR SELECTED NODES 1 TO 88312 BY 1
REAL= 0.00000000 IMAG= 0.00000000
ADDITIONAL DOFS= UZ ROTX ROTY ROTZ
SELECT ALL ENTITIES OF TYPE= ALL AND BELOW
TIME= 1.0000
***** ANSYS SOLVE COMMAND *****
*** WARNING *** CP = 673.125 TIME= 11:16:45
Previous testing revealed that 141 of the 93430 selected elements
violate shape warning limits. To review warning messages, please see
the output or error file, or issue the CHECK command.
*** NOTE *** CP = 673.172 TIME= 11:16:45
The model data was checked and warning messages were found.
Please review output or errors file for these warning messages.
*** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
---GIVE SUGGESTIONS ONLY---
ELEMENT TYPE 1 IS SOLID185. IT IS ASSOCIATED WITH LINEAR MATERIALS ONLY
AND POISSON'S RATIO IS NOT GREATER THAN 0.49. KEYOPT(2)=3 IS SUGGESTED.
ELEMENT TYPE 3 IS SHELL181. IT IS ASSOCIATED WITH ELASTOPLASTIC
MATERIALS ONLY. KEYOPT(8)=2 IS SUGGESTED AND KEYOPT(3)=2 IS SUGGESTED FOR
HIGHER ACCURACY OF MEMBRANE STRESSES; OTHERWISE, KEYOPT(3)=0 IS SUGGESTED.
ELEMENT TYPE 4 IS BEAM188 . KEYOPT(3) IS ALREADY SET AS SUGGESTED.
ELEMENT TYPE 4 IS BEAM188 . KEYOPT(15) IS ALREADY SET AS SUGGESTED.
S O L U T I O N O P T I O N S
PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
DEGREES OF FREEDOM. . . . . . UX UY UZ ROTX ROTY ROTZ
ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
PLASTIC MATERIAL PROPERTIES INCLUDED. . . . . .YES
NEWTON-RAPHSON OPTION . . . . . . . . . . . . .FULL UNSYMMETRIC
GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .UNSYMMETRIC
*** NOTE *** CP = 673.906 TIME= 11:16:45
The shear transfer coefficient(s) for a closed crack is recommended to
be less than 1.0 for material 1.
*** NOTE *** CP = 673.969 TIME= 11:16:45
Results printout suppressed for interactive execute.
The conditions for direct assembly have been met. No .emat or .erot
files will be produced.
*** NOTE *** CP = 674.141 TIME= 11:16:45
Internal nodes from 88313 to 89764 are created.
1452 internal nodes are used for quadratic and/or cubic options of
BEAM188, PIPE288, and/or SHELL208.
L O A D S T E P O P T I O N S
LOAD STEP NUMBER. . . . . . . . . . . . . . . . 1
TIME AT END OF THE LOAD STEP. . . . . . . . . . 1.0000
AUTOMATIC TIME STEPPING . . . . . . . . . . . . ON
INITIAL NUMBER OF SUBSTEPS . . . . . . . . . 1000
MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . . 50000
MINIMUM NUMBER OF SUBSTEPS . . . . . . . . . 500
MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . . 100
STEP CHANGE BOUNDARY CONDITIONS . . . . . . . . NO
LINE SEARCH . . . . . . . . . . . . . . . . . . ON
TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (REMAIN)
CONVERGENCE CONTROLS
LABEL REFERENCE TOLERANCE NORM MINREF
F 0.000 0.1500E-01 1 0.000
U 0.000 0.1000 0 0.000
COPY INTEGRATION POINT VALUES TO NODE . . . . .YES, FOR ELEMENTS WITH
ACTIVE MAT. NONLINEARITIES
PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
DATABASE OUTPUT CONTROLS
ITEM FREQUENCY COMPONENT
ALL -10
SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
*** NOTE *** CP = 677.750 TIME= 11:16:47
Smoothing on certain target nodes (e.g.73) for pair ID 20 may have
accuracy issue. Please verify element normal of connected target
elements (e.g.82337 & 82338).
*** NOTE *** CP = 678.125 TIME= 11:16:47
Deformable-deformable contact pair identified by real constant set 20
and contact element type 32 has been set up.
Auto surface constraint is built
Contact algorithm: MPC based approach
Contact related post- process items (ETABLE, pressure ...) are not
available.
Contact detection at: nodal point (normal to target surface)
*WARNING*: Smoothing on certain contact/target nodes (for example 73)
may have an accuracy issue. You may switch contact and target
surfaces, or split the current pair into multiple pairs, or use Gauss
detection.
MPC will be built internally to handle bonded contact.
Average contact surface length 2.0000
Average contact pair depth 2.0000
User defined pinball region PINB 6.2500
Default target edge extension factor TOLS 10.000
Initial penetration/gap is excluded.
Bonded contact (always) is defined.
*** NOTE *** CP = 678.141 TIME= 11:16:47
Max. Initial penetration 2.009718347E-14 was detected between contact
element 84895 and target element 82708.
Deformable-deformable contact pair identified by real constant set 21
available.
*WARNING*: Smoothing on certain contact/target nodes (for example 673)
detection.
Max. Initial penetration 1.065814104E-14 was detected between contact
element 91961 and target element 89851.
Element Formation Element= 1000 Cum. Iter.= 1 CP= 679.453
Time= 0.10000E-02 Load Step= 1 Substep= 1 Equilibrium Iteration= 1.
NUMBER OF SMP THREADS USED = 4
ELEMENT FORMULATION CP TIME = 13.797
ELEMENT FORMULATION ELAPSED TIME = 3.448
*********** PRECISE MASS SUMMARY ***********
TOTAL RIGID BODY MASS MATRIX ABOUT ORIGIN
Translational mass | Coupled translational/rotational mass
206.25 0.0000 0.0000 | 0.0000 7422.1 -9899.8
0.0000 206.25 0.0000 | -7422.1 0.0000 7422.4
0.0000 0.0000 206.25 | 9899.8 -7422.4 0.0000
| Rotational mass (inertia)
| 0.10650E+07 -0.35628E+06 -0.26724E+06
| -0.35628E+06 0.85139E+06 -0.35625E+06
| -0.26724E+06 -0.35625E+06 0.10652E+07
TOTAL MASS = 206.25
The mass principal axes coincide with the global Cartesian axes
CENTER OF MASS (X,Y,Z)= 35.988 48.000 35.986
TOTAL INERTIA ABOUT CENTER OF MASS
0.32275E+06 -4.7850 -137.49
-4.7850 0.31718E+06 2.8307
-137.49 2.8307 0.32294E+06
The inertia principal axes coincide with the global Cartesian axes
*** MASS SUMMARY BY ELEMENT TYPE ***
TYPE MASS
1 198.758
3 0.100037E-28
4 1.67249
24 5.81809
Range of element maximum matrix coefficients in global coordinates
Maximum = 60690186.4 at element 46991.
Minimum = 1.039100299E-23 at element 38186.
*** WARNING *** CP = 693.172 TIME= 11:16:52
Coefficient ratio exceeds 1.0e8 - Check results.
*** ELEMENT MATRIX FORMULATION TIMES
TYPE NUMBER ENAME TOTAL CP AVE CP
1 35905 SOLID185 36.078 0.001005
3 9708 SHELL181 5.281 0.000544
4 1452 BEAM188 2.750 0.001894
24 7445 REINF265 6.812 0.000915
31 1496 TARGE170 0.000 0.000000
32 9600 CONTA174 3.781 0.000394
Time at end of element matrix formulation CP = 693.171875.
ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= file.rdb
FOR POSSIBLE RESUME FROM THIS POINT
FORCE CONVERGENCE VALUE = 0.1181E+05 CRITERION= 177.2
Writing NEWTON-RAPHSON residual forces to file: file.nr002
ZeroThreshold value for dropping near-zero values is set to: 0.1000000000E-13
MultiSolution: Sparse Assembly Option .... Call No. 2
ANSYS largest memory block available 1086062144 : 1035.75 Mbytes
ANSYS memory in use 2674619200 : 2550.72 Mbytes
ANSYS max memory used 868689280 : 4924.45 Mbytes
Sparse Solver Interface Adding CEs.... Call No. 2
Sparse CE interface Matrix dim coefs mxcolmlth
Original A22 198432 13408434 159
Constraints G 29400 92166 4
H = G*A11 + A12T 29400 1337924 72
HGT 198432 765974 291
Modified A22 198432 14586088 300
ANSYS largest memory block available 965686400 : 920.95 Mbytes
ANSYS memory in use 2720940864 : 2594.89 Mbytes
CPU time for processing CEs = 0.69 secs
WALL time for processing CEs = 0.18 secs
ZeroThreshold value for dropping near-zero values when writing matrix has been adjusted to: 1.0000000000E-103
End of PcgEnd
ANSYS largest memory block available 1333729920 : 1271.94 Mbytes
ANSYS memory in use 2415044736 : 2303.17 Mbytes
ANSYS max memory in use 868689280 : 4924.45 Mbytes
Total Time (sec) for Sparse Assembly 1.89 cpu 0.55 wall
SPARSE MATRIX DIRECT SOLVER.
Number of equations = 166250, Maximum wavefront = 600
ncoefKL/neqn = 63.8
Distributed Sparse solver memory mode has been set to in-core mode
after mf2Sym on process 0
Currently using = 1687396
Needs for next phase = 2318237
Estimates of speedups
FctSpeedup SlvSpeedup VctSpeedup
1.000 1.000 1.000
Call to mf2LOps
my_Lnz my_ops ttl_Lnz ttl_ops
100386032. 347851696352. 100386032. 347851696352.
min Lnz max Lnz ratio
0.10038603E+09 0.10038603E+09 1.0000
min ops max ops ratio
0.34785170E+12 0.34785170E+12 1.0000
Memory allocated for solver = 2396.554 MB
Memory required for in-core solution = 2102.098 MB
Memory required for out-of-core solution = 501.783 MB
*** NOTE *** CP = 698.219 TIME= 11:16:55
The Sparse Matrix Solver is currently running in the in-core memory
mode. This memory mode uses the most amount of memory in order to
avoid using the hard drive as much as possible, which most often
results in the fastest solution time. This mode is recommended if
enough physical memory is present to accommodate all of the solver
data.
The system matrix is unsymmetric.
adjust near zero pivots tolerance = 3.857050251108614E-098
curEqn= 20 totEqn= 166250 Job CP sec= 699.078
Factor Done= 0% Factor Wall sec= 647.793 rate= 0.0 Mflops
*** WARNING *** CP = 710.688 TIME= 11:16:58
mode and pivoting has been turned on for this problem. For
robustness, it is generally recommended to run in the out-of-core mode
when pivoting is turned on as the amount of memory needed by the
Sparse Matrix Solver cannot be accurately predicted before calling the
solver. If a memory error occurs, please change the memory mode by
using the DSPOPTION command.
1.000 1.000 1.000
Call to mf2LOps
Memory allocated for solver = 2615.971 MB
*** NOTE *** CP = 711.047 TIME= 11:16:58
data.
*** WARNING *** CP = 711.047 TIME= 11:16:58
Pivoting has been activated for the Sparse Matrix Solver . The memory
required may greatly exceed the predicted amount. In that event, use
the DSPOPTION command to change the memory mode and/or memory size
used by the Sparse Matrix Solver.
curEqn= 24176 totEqn= 166250 Job CP sec= 967.125
Factor Done= 48% Factor Wall sec= 715.523 rate= 233.1 Mflops
curEqn= 49428 totEqn= 166250 Job CP sec= 1228.219
Factor Done= 98% Factor Wall sec= 780.942 rate= 435.3 Mflops
*** WARNING *** CP = 1232.766 TIME= 11:19:09
There is not enough memory for the Sparse Matrix Solver to proceed in
the in-core memory mode. The Sparse Matrix Solver will now restart
using the out-of-core memory mode.
Distributed Sparse solver memory mode has been set to optimal out-of-core mode
1.000 1.000 1.000
Call to mf2LOps
Memory allocated for solver = 533.341 MB
Memory required for out-of-core solution = 361.573 MB
The number of ERROR and WARNING messages exceeds 5.
Additional messages suppressed. See for suppressed messages.
*** NOTE *** CP = 1234.516 TIME= 11:19:11
terminating : mf2Factor error 75
Sparse Matrix Solver CPU Time (sec) = 617.594
Sparse Matrix Solver ELAPSED Time (sec) = 305.846
Sparse Matrix Solver Memory Used ( MB) = 533.341
End of PcgEnd
ANSYS memory in use 2419065984 : 2307.00 Mbytes
Total Time (sec) for Sparse Assembly 619.50 cpu 306.43 wall
*** NOTE *** CP = 1315.016 TIME= 11:22:00
Solution not converged - Skipping the remaining commands to the FINISH
command.
***** ROUTINE COMPLETED ***** CP = 1315.172
I have tried adjusting the DSPOPTION to use the in-core memory, but is still struggling to start solving. Any help would be appreciated.
