Equivalent R- Value calculation of metal/insulation wall
jddj
I have a spreadsheet that calculates the equivalent R-value for parallel heat flow through wall studs and insulation. I have always used this spread sheet on typical wall sections with wood studs and batt insulation and seem to have got reasonable numbers. The equation in the spreadsheet is basically U_eq = (1/R_stud)*(stud width/stud spacing) + (1/R_insul.)*(Insul. width/stud spacing) and R_eq = 1/U_eq
I tried using this spreadsheet on a different wall assembly that has thin metal plates between the insulation, so basically I replaced the wood studs information with the metal plate information. I came out with a number that was quite a bit lower than what I had expected. I have seen articles online that state metal stud walls typical have an equivalent R value of 40-50% of the insulation value, and I'm coming up with around 3% from my spreadsheet.
I know I'm not providing any specific numbers, I'm just curious if there is a different approach when dealing with metal as opposed to wood?
Thanks for the response, I will review my inputs and see if anything else looks off.
double-check & units of measurement are consistent
