supergee
- Aug 15, 2012
- 84
Hello all,
I've tried seaching the standard and the threads but can't find a clear answer.
A student gave me a drawing of a sheet metal part that is bended to look like a "U". Two coaxial holes are made on each side of the "U". The student decided to make the holes Continuous Features in order not to calculate the Frtz value... I know...students are sometimes lazy...![[wink] [wink] [wink]](/data/assets/smilies/wink.gif)
Is this abusive? I mean, logically, in that particular case, the holes would be laser cut (or any other process) on the sheet metal BEFORE it would be bent into shape. Using <CF> would imply the holes being drilled together after the bending. (I know the standard does not dictate the manufacturing process)
