The Jacobi Method
hoshang
497
Re Example 11.9 from Klaus-Jurgen Bathe's Finite Element Procedures textbook,
in first sweep, I could get big lambda and big phi,
in second sweep, I could get big lambda, but failed getting big phi,
in third sweep, I could get big lambda, but failed getting big phi,
Does this make sense? How can I get the correct big phi in second and third sweep?
If needed, I can post my calculations.
IRstuff said:
How else would anyone even being to guess at what might be wrong?
Have you reviewed Example 11.9? Did you try it yourself? In My OP, I stated If needed, I can post my calculations.
So, here's a link to my calculations for the second sweep:
 https://files.engineering.com/getfile.aspx?folder=90dfaaee-9789-4ae0-b6a6-d2a24f2a1c37&file=The_Jacobi_Method.pdf
Hi all
Any help would be highly appreciated.
