Contact US
ASME Section IX- PQR Issues related to Governing Thickness and Buttering
I need to qualify a buttering procedure for P22 to 800H. Client specified a process where bi-metallic welds like this need to be buttered first. For bimetallic weld, 2.25Cr should have a 1/4" butter layer and PWHT before welding to 800H. My joint configuration is very weird. I have a P22 flange of 2.25" thickness that needs to be drilled with hole on the side (curvature face). Hole on P22 will be buttered with ErNiCrMo-3 wire and need to PWHT. After PWHT pipe made of 800H NPS 1.25 SCH 160 (0.25" thk) will be welded on buttered layer . Pipe needs to have a bevel and it will be a full pen joint followed by fillet on top.
With these uneven thicknesses (2.25" and 0.25"), i am not sure what thickness and configuration should i use for procedure qualification?
Please refer attached image and suggest.
Thank You!
RE: ASME Section IX- PQR Issues related to Governing Thickness and Buttering
I believe you have two options.
Reference ASME IX QW-451.
1.5" thick 2.25Cr Plate (SA-387) buttered with 1/4" ERNiCrMo-3 and PWHT as per production joint.
Weld the buttered plate to SB-409 plate of equal thickness (1.5"). This plate may be difficult to find and purchase.
Your qualified base metal thickness range, according to QW-451 will be 3/16" to 8" and should cover you for both materials.
This will be difficult to weld, but easy to remove the required test specimens for procedure qualification.
Alternatively, you could do a production mockup. Purely my opinion here. This one you would need some customer approval/input.
But, in my mind, this joint very much resembles a tube-to-tubesheet weld. Review QW-193 for specifics on procedure/performance qualification. It's fairly straight forward and simple.
If I was the customer in this case, with what information I have at the moment, I personally would be very amenable to qualifying the joint in this manner.
Your mileage may vary.
The devil is in the details; she also wears prada.
Hello. May i offer my opinion here.
It is not appropriate to invoke QW-193 here, because that clause is strictly meant for tube to tubesheet welds.
In this case, if i had to decide on it - i would take a 1.25'' P22 plate, butter it with ERNiCrMo-3, heat treat it, and subsequently make a butt weld with 800H material.
The thickness of 800H material is to be chosen with some thought here. Like someone said above, finding a 1.25 inch thick 800H plate may be a bit of a hassle.
So, if the qualification is being done only to serve the weld described in question, it is enough to take any thickness 1/8 inch onwards (say 1/4 inch thick plate).
This would be a dissimilar thickness joint, and would qualify a thickness range of 5/16 inch to 2.5'' on P22 side welded to 1/16 inch to unlimited thickness on 800H side (considering QW-202.4(b)(1)).
Best of luck!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
