ESD valve location - Guide 3
Justice100
Chemical
GB
Hi all,
Is there a good reference document or article that discusses the location of ESD valves?
E.g. ESD valves are located on the liquid outlet of vessels presumably to isolate the liquid inventory in case of a leak. Also, they will be at fire area boundaries to prevent flammable materials from one area feeding another.
Hope it's not too late, I haven't checked eng-tips for a while.....
CCPS Best Practices Guide - Remote Isolation of Process Equipment
CCPS Hazard Evaluation Guidelines 1st Edition Appendix A-7
Remotely operated shut-off valves (ROSOVs) for emergency isolation of hazardous substances: Guidance on good practice HSG24410
AIChE CCPS Guidelines for Fire Protection in Chemical, Petrochemical, and Hydrocarbon Processing Facilities
API RP 553 Refinery Valves and Accessories for Control and Safety Instrumented Systems Chapter 8 Emergency Block Valves
Emergency Block Valves, Global Asset Protection Services GAP.8.0.1.3, 2001
Thanks! That’s an extensive list, I’ll see what I can get my hands on
