Contact US
Auto-Counting and Sorting Threads in a Part
Hi everyone :)
I want to create a macro in Catia v5 R2020 that replicates the Thread/Tap Analysis feature from previous versions of the software. My goal is for the macro to automatically detect all threads in my part, categorize them by diameter, and provide a count of each thread size (ex. Total Threads = 130. M6 = 126, M24 = 4).
I’ve tried searching for every Thread in the Technological Results, but I’m not sure how to sort them by diameter. This, i think, is complicated by the fact that threads are generated by various features like Threaded Hole, TapHole Assemble (with isolated body), Mirrored holes, and User/Circ Patterns.
Is there a way to do this?
Thanks in advance
RE: Auto-Counting and Sorting Threads in a Part
First, I Would suggest to find hole feature, and analyse the dimensions of the feature, and as well if thread is defined or not!
Then you have the patterns. Lets make the first step and then we will figure out something!
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
I started and you can continue to code :)
just fill the points you need to add your choices.
CODE -->
Sub ThreadAnalysis()
    Dim partDocument As PartDocument
    Set partDocument = CATIA.ActiveDocument
    Dim part As Part
    Set part = partDocument.Part
    ' Dictionary to store thread diameter and count
    Dim threadCounts As New Scripting.Dictionary
    Dim features As HybridBodies
    Set features = part.HybridBodies
    ' Loop through hybrid bodies
        Dim hybridBody As HybridBody
        Set hybridBody = ' ...
        Dim feat As HybridShape
        For Each feat In hybridBody.HybridShapes
            ' Check if feat is a thread feature and extract relevant information
            ' Categorize and count threads
        Next feat
    ' Display the results to the user
End Sub
Thanks guys, I'll work on it now and later I'll share what I got
Hi everyone,
unfortunately, I haven't been able to find a solution to this problem yet. I tried to complete the code provided by Dialga1, but, due to my lack of VB experience, I couldn't get it to work.
I think a good strategy is to detect all the Holes in a part and detect the holes that have a diameter equal to a value stored in a dictionary (I don't need to check if a hole is threaded or not). Then I just have to count how many objects there are in the various groups of the dictionary.
Please, can you help me to do that?
Francesco
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
