Contact US
spreadsheet for cam/roller Hertzian contact stress with double curvatures
hello, I am trying to write an excel spreadsheet for calculation of Hertzian max contact stress btw cam (body#1) and roller (body#2).The cam has a flat lobe (no transversal curvature)but the roller has a "crown" defined by a radius of curvature.The input data are cam geometry defined by the raius of curvature and loads (both expressed by angular value with resolution = 1 deg). Then I have applied the formulas to calculate the semi-minor & semi-major axis of contact and ultimately the max Hertzian contact pressure which is the final goal and the entire focus. The result I am getting doesn't look promising (values smell much too low) so there is likely to be some error but I was not able to find it. One possible reason could be the definition of radius of curvatures but I think they are all positive (+) since they are all positioned within the direction of their respective bodies. The coefficients μ(θ)and ν(θ)
are obtained by extrapolation of exponential model and should be OK.
So here the spreadsheet and I would appreciate everyone comments. thanks!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
