12v dc relay connection
A1Marine
Marine/Ocean
I'm needing the following schematic and switches necessary to do the following.
I need 2 engines oil pressure to enable current to switch to on, a single fuel pump whenever either engine is on line. This pump is also 12v and will function full time as long as either engine is operating. Is there a ready made relay assembly available for this turn key function?
Marine professional
Any suitable relay and two diodes, one from each pressure switch.
Or, both pressure switches in parallel.
It depends on where you source your current.
Ohm's law
Not just a good idea;
It's the LAW!
WAROSS
The supply is coming from a battery 1 each for each engine completely separate supply systems.
Can you draw a schematic and parts needed?
This is what I had figured so far.
NO switches in the oil circuits of each engine.
Power supply from the local battery fused to one side of the OP switch and flowing to the sense of the relay. Actuating the relay to the load 15a of the relay to the fuel pump.
I think this is correct and stand to be corrected if you will. I also need the single pump to turn on with either engine running. Is there diodes to be installed?
Thanks and can you draw the schematic.
2 engines, 1 pump, all 12 v.
Marine professional
Engine one;
Battery 1, to fuse 1 ,to diode, 1 to relay, to common ground.
Engine two:
Battery 2, to fuse 2, to diode 2, to relay, to common ground.
Pump source. to fuse, to relay, to pump, to ground.
OR
Battery 1, to fuse 1, to relay 1, to ground 1.
Battery 2, to fuse 2, to relay 2, to ground 2.
Pump source. to fuse, to relays 1 & 2, relay contacts in parallels, to pump, to ground.
Ohm's law
It's the LAW!
