Abqus shows error while running in paralleization
Rajesh_kumar
3
I want to speed up the process in abaqus ,while using parallelization I am getting this error"The executable explicit_dp.exe aborted with system error code 3. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code."
But when i am using two processors it is running fine.Does anyoneone know how can I resolve it ?
Did you check those files (.dat, .msg and .sta) ? Do they contain any additional errors ?
