I am working on a 1975 Super Beetle. The passenger side wheel sticks out of the wheel well about 3/4 inch and the drivers side wheel is tucked under the fender.
75 had a Strut suspension and when I adjusted the concave bolt for camber adjust in an attempt to pull the wheel further in only resulted in lot of "Toe" problems.
My question is this:
I am using a 17x7.5 width wheel with ET52.
I am thinking of putting a 7 inch wheel on the passengers side to pull it under the fender.
This will mean that I will have mis matched wheels on the front by 1/2 inch but the tire size will still be the same (205/40R17)
Will this cause any problems?
I will of course take it to a Alignment shop after this is completed.
Thanks for any help.
