If we have a sprung system, so springs on all four corners, why does the system not have 'design' weight distribution at any ride height? Adjusting my car I can change the load on the corner by adjusting the ride height through the coilover spring seat height. But the spring preload on each corner should always be the same as it's displaced the same amount by the mass, I should only be changing the total length of the strut by moving the spring seat. Is the subsequent change in cross-weight because of actual CG being tilted or is there some other effect?
