Centrifugal pump thermal relief equation....
quizzical1
180
Hi All,
NFPA 20 4.13.1.4 states “The valve shall provide sufficient water flow to prevent the pump from overheating when operating with no discharge”.
Does anyone know where I can find the equations or an online calculator to quantify the required flow for keeping an idling centrifugal pump cool?
thanks,
Q~
Normally min flow is about 30% of rated flow.
