CeaserMech
I am working on a job that is using a cooling tower with a chiller, but the refrigerant from the chiller is piped directly into the cooling tower, so technically its an evaporative condenser rather than a heat exchanger between.
I am trying to figure out what the code requirements are for efficiency of this type of system. I see the title 24 chart that shows the following:
Looking for some advisement
