Jordan Adkins
Hello everybody.
Looking for some clarification or input on an engineering theory. If feeding a "loop" from two sources, you can effectively add 1.5x to your capacity.
In the example below, there is an 8" compressed air main from the compressor building into the plant. From this 8" line, there are (2) 4" sub headers. Let's say (for easy numbers0 that each of the 4" sub headers each have a carrying capacity of 1,000 SCFM.
Does tying these (2) sub headers together in essence turn the 4" loop into (1) 4" sub header with a 1.5x capacity multiplier for a total of 1,500. OR would you add the total of the (2) 4" sub headers together (1000+1000) and then add the 1.5x multiplier for a SCFM capacity total of 3,000?
Any input or literature that can be provided would be very helpful and much appreciated.
Thanks in advance.
Thanks in advance.
