Bathroom Exhaust Fan
Designer_82
Dwelling unit bathroom exhaust fan has the exhaust duct run pretty far and it's not pulling any air.
Is the typical solution to this a booster fan or something else?
New bathroom exhaust fan, with correct static pressure rating. Is there a reason why you'd install a second fan when you can just replace the original?
How far?
Either make the duct bigger or install a more powerful fan. Read the t echo details on the fan units as to maximum length of duct.
Is the duct blocked or restricted somewhere.
No air movement or not much? Use a piece of tissue to see
If the ESP doesn't match the one that's already there, measure it and change the fan instead of putting in a new fan with its ducting
The problem with the world is that intelligent people are full of doubts, while stupid ones are full of confidence.
-Charles Bukowski-
What length, size, desired flowrate and the actual flowrate?
