Spindle torque, belt driven
aldumoul
65
Wondering what the torque would be in a 2.5” dia. Spindle. Spindle speed=9,000 rpm. Spindle is driven by the motor, pulley ratio is 2.57:1. Shaft weighs 66 lbs.
Motor torque = 40.2 lb-ft
Motor hp = 15 hp
Motor speed = 3500 rpm
Motor shaft/rotor inertia = 0.474 LB-FT^2
I calculated the max allowable torque of the shaft, no bending stress. So looking to see if I’d be beyond that. Probably gave more info than needed, but want to make sure I’m not missing anything.
Thank you!
You are correct used the full load torque. Breakdown torque is 103 lb-ft.
Sounds like I should’ve went with my original calc.. 2.57*motor torque of 103lb-ft
How about 103/2.57
Sped goes up, torque goes down.
You can't create HP out of thin air.
Yes, 103/2.57. Realized my mistake after I submitted the post :)
Thanks!
HP = Torque (lb-ft) x RPM / 5252
So, relatively small torque for a relatively large shaft.
Stiffness matters.
Distance between supports, straightness and balance matter at 9,000 rpm.
