Scale Factor and Safety Factor in Hypermesh / Optistruct
Platypusimon
Aerospace
Jan 20, 2023
11
I have question about safety factors. In the software HyperMesh/Optistruct, in the load collectors, when you select the Card Image LOADADD, you can apply a scale factor (real). This Scale Factor for me resembles a Safety Factor to me, as it multiplies the value of each load by the scale factor you choose to put.
By checking in the manual, I seem to see it does. But I am not entirely sure, because why wouldn't it just be called safety factor in that case? Or does it do something quite different which I have not fully grasped.
Much appreciated for whoever can answer me. I have attached relevant screenshots and links underneath.
There are many reasons you might want to scale an applied load. E.g your FEM might have a unit applied load defined, which you might then scale by a different factor for each load case.
