Valve working principal
KAGAME
Automotive
Apr 8, 2023
1
Hello!
My name is KAGAME Yves, I am an electromechanical engineer. I need an assistance from you guys about the KRACHT hydraulic valve that I don’t understand it working principal. I took it from a Caterpillar compactor, but I still don’t understand how it been interacting with other components. Below are some of its photographs to check on if you can recognize it.
Suggest to contact the KRACHT vendor for the manual of the D598 Werdohl. Per Google search, D598 is a hydraulic pump, instead of valve.
Good luck.
