rollingcloud
Aerospace
Specifically, can both 15-5PH and 17-7PH heat treated to CH900 as an assembly? From AMS2759/3 tables, it looks like CH900 only exists under 17-7PH, for 15-5PH, the closest condition is H900 which is what we wanted.
I guess the question boils down to if CH900 condition can be viewed as heat treatment process and the results will just dependent on the starting metal (My supervisor’s view). My interpretation is that CH900 is only a hardness condition as the table in the spec showed, otherwise, the spec could have used conditions to replace the heat treat process, besides, “condition” literally means state, not “process” or “treatment”.
Also, does the spec define the prefixes CH and H?
