Abaqus: Update part in assembly
DKEngineer
Student
Apr 3, 2023
20
In assembly module I am using the "Create instances" and "merge/cut instances" tool to partition a part using a shell part as partitioning geometry.
This works fine. But when i edit one of the original parts in the part module, the assembly doesnt change corresponding to the edited part. Is there any way to do this?
This method creates a new part that is not linked to the original parts. You would have to use Merge/cut instances again to create a new part with those changes.
