FE modeling of fuselage frames
Andries
Member
Mar 9, 2001
158
Good Day Colleagues,
I noticed that in two different aircraft company finite element manuals the light frames typically used in airliner fuselages
are represented by Nastran CRODS for the flanges of the stringer and a single QUAD4 element representing the web.
Surely a single QUAD4 will be too stiff?
Any views on this?
Thanks.
Andries
Presumably that is for a loads FE model only, and not a stress FE model. And that sounds like a 1980's modelling approach when computing power was much less; likely that current FEMs are more detailed.
Thanks Gentlemen,
Yes, it is for a loads model.
Andries
There are some great notes from Ian Taig on this around. This is a reliable means. Complexity leads to error. Review Cook.
Thanks SAITAETGrad,
I fortunately have Cook's book and copies of Taig's notes; they really get down to the nitty-gritty of FE modeling.
(As far as FE text books go Cook et al is one of the best.)
On further reflection and the replies above I can now understand the use of a single CQUAD4 as a frame web.
I do think, however, that for spar webs one should have more CQUAD4s, say 4 - 6, down the depth of the web, as mentioned in earlier threads.
Thanks again to all the respondents.
Andries
