Help with RISA 3D output, what is the meaning of the DISTRIBUTED column
ac0609
Hi everyone,
I have a RISA 3D output and wondering what the meaning of the DISTRIBUTED column for BASIC LOAD CASES spreadsheet. I attached an image hopefully this helps. I tried looking for the meaning in the General Manual but could not find anything
Thanks in advance.
That is showing the number of applied distributed loads that exist in your model.
P.S. why do you have a -1.2 factor on the self weight? If that's for factoring to LRFD loads, that factor should be applied in the load combos, not the load case factors.
I think thats the number of assigned distributed loads for each BLC.
I am accounting for something else in this model. I added 20% for connections.
In RISA verbiage, a distributed load is a line load on a member. As dold said, the number represents the total number of those line loads in that basic load case.
The BLC window is the best location to view all of your applied loads. There is a column for Nodal, Point, Distributed, Area. Click any of those cells and it'll open up the corresponding load type with the selected BLC (gravity, railing, etc.) open.
