Error: Bulk temperature is undefined for convection surface element
SteffB
3
I try to use surface elements (surf152) for applying
I try to use surface elements (surf152) for applying convection load.
Unfortunately, I gathered some error message:
*** ERROR *** SUPPRESSED MESSAGE CP = 2.000 TIME= 15:21:59
Bulk temperature is undefined for convection surface element 1281. Use
SFELIST or SFLIST command to find other elements without bulk
The APDL snippet I use is the following:
solve
save,file,db
/prep7
/GOPR
/com,!---------------------------------------------------------------------------------------------------------------------!
/com,Start surf152 for conv
esel,s,ename,,152 ! Element selection of surf152 elements
cm,ELsurf152,elements ! Create a component which includes surf152 elements
edele,ELsurf152 ! Deletion of former surf152 elements
et,100,152
keyopt,100,4,1
keyopt,100,5,0
keyopt,100,8,3
cmsel,s,external,node
esln,all
type,100
esurf
esel,none
esel,s,type,,100
esel,stat
esel,s,ename,,152
esel,stat
cm,surfElem152,elem
esel,stat
allsel,all
outres,all
save,file,db
/com,End surf152 for conv
/solu
! trnopt,full
! nropt,full
! thopt,full
save,file,db
antype,,restart
/com,Post for surf152
/post1
set, last
esel,s,ename,,152
esel,stat
save,file,db
/solu
antype,,restart
/com, Start surf152 selection for conv
esel,stat
sfe,all,1,conv,1,hflux_test
/com, Ende surf152 selection for conv
allsel,all
outres,all,all
*enddo
I don’t know how to define the bulk temperature.
Maybe someone has a hint how to achieve this.
With best regards
Steff
