Incorrect Hole on the ASME Head
Hello Everybody:
I have 5/16" THK Stainless Head. I need to patch a 6" hole in the head? Does ASME Sec VIII Div 1 allows to do this? If yes, what NDE methods should I use after patching.
Please help
Thank You
Dave
Please help
Thank You
Dave
RE: Incorrect Hole on the ASME Head
-Christine
If this is a seamless head you may have to do 100% RT for your E=1.0 head calculations to still be valid (I may be wrong about this, not sure really).
Also depending on the size of the opening your client may prefer you to use a flush patch that has been dished in order to match the head dish radius, otherwise the head would have a flat spot.
-Christine.
Mike
This is a two piece head with 100% RT came with partial data report. The E used in the calcs is 85%
I was thinking it will come under spin hole category where you can plug the hole & perform a PT inspection. But there is a restriction on diameter for doing this. I think the best bet here is Patch with Full Penetration & 100% RT to maintain 85% efficiency.
Please comment your suggestions. thank you
Edition/Addenda: 2013 Eidtion
Para./Fig./Table No: UW-34
Subject Description: Spin-Holes
Date Issued: 09/16/2015
Record Number: 15-1429
Interpretation Number :
Question(s) and Reply(ies):
Question 1: Does paragraph UW-34 prohibit the use of spin holes that are greater than 2 3/8 inches (60 mm) diameter in formed heads?
Reply 1: No.
Question 2: If a spin hole larger than 2 3/8 inches (60 mm) is closed using a butt welded plug, is it required to apply the applicable joint efficiency of Table UW-12 to this weld for the design of the head or head-to-shell joint?
Reply 2: Yes.
Standard Designation: BPV Section VIII Div 1
Edition/Addenda: 2015 Edition
Para./Fig./Table No: Paragraph UW-34
Subject Description: Section VIII, Division 1; UW-34 - Spin Hole Plug Configuration
Date Issued: 12/08/2017
Record Number: 17-1867
Interpretation Number : BPV VIII-1-17-77
Question: May an opening in a head be closed with a welded plug categorized as a Category A weld joint, and the head thickness calculated following the current code rules for weld type and extent of examination?
Reply: Yes.
