Equal areas or equally spaced locations on irregular surfaces
gergs
Computer
Aug 20, 2004
94
Hello all,
I want to take any irregular surface/face that I choose and either divide it into lets say 12 equal patches of the same area. Or equally useful would be to place 12 objects on the surface/face all equally spaced apart from each other.
Does anyone know a method to do this? Or something similar with curves or patterns or something? It's finding the spacing and locations to place those 12 objects that I am after. (12 is arbitrary just as an example. See image)
Thank you.
 https://files.engineering.com/getfile.aspx?folder=b9f046af-09a2-4421-9b10-a91b1759271e&file=example.png
I assume that this could be done using the algorithmic modeling rules.
( I do not know how)
Tomas
The more you know about a subject, the more you know how little you know about that subject.
