NX Polygon modeling fill hole fails
BassinDanton
Industrial
Mar 21, 2023
1
Hello everyone, first time using this forum.
I am trying to merge two disjoined pipe-like faceted bodies through the connected holes feature of 'Fill Hole'.
The faceted bodies tips have been trimmed with the Snip function (snip facets parameter enabled).
The preview gives the expected result but the function fails when executing it.
Editing a copy or removing dependences through making non-associative copies of the faceted bodies does not help either.
Would you mind giving me tips as to how to run this function or if there is a better way to bridge the two bodies?
