Ancient spread sheet formats 1
dgallup
Automotive
May 9, 2003
4,715
I'm trying to open some files from 1997. Pretty sure they are spreadsheets but I don't know what software. I've got.WB1 and .WK1 files. Excel 2016 doesn't know what to do with them and if I do open them it's gibberish. Are these Quattro files? Any tips on how to open them?
Look here under "File formats that are not supported in Excel".
WK1 is Lotus 1-2-3
WB1 is Quattro Pro
I just opened LibreOffice and it lists WB1 and WK1 formats in it's File Open dialog.
Just found a .WQ1 file too. Looks like various versions of Quattro and Lotus. Supposedly I could download Correl WordPerfect Office but not sure I want to go that route.
I still have an original 5-1/4 of Visicalc... no idea of what the access code is, anymore... also no idea of what the file extension was.
I was able to find .PRN files that came from the test machine that (I think) was the input to the old spreadsheets. Not sure I got all the headers, etc. exactly right but it's good enough for my purposes. Thanks for your help.
I have a working copy of Lotus 123, which will also open Quattro Pro files. I'd be happy to open and convert to Excel if anyone needs help with that.
Doug Jenkins
Interactive Design Services
Thanks, IRS... it's been 30 years since I used it... was great at the time.
It still is :)
I've got a few spreadsheets I set up about 20 years ago that I can't replicate in Excel without days of work, so it's easier just to keep 123 installed so I can keep using them.
Doug Jenkins
IDS,
Wow! give me a couple of weeks, I may have some old QPro & Lotus files to convert. I really liked QPro til corporate decided on MS Office.
Thanks.
IDS,
I just checked my QPro files & I converted all my QPRO files (*.wb1 & *.wq1) to OSX Excel format using LibreOffice in 2018 & did not remember.
The conversion process using LibreOffice appears thorough & I can open the converted files.
Geoff13 is correct, LibreOffice works in converting Lotus 123 (*.wk1) files and Quattro Pro (*.wb1 & *.wq1) files.
Thanks for the offer.
We started with Visacalc. It ran on a Radio Shack Model II. Later we moved over to Lotus 123. Have many files in WK1. Can open with Excel and Libre and save to Excel. The macros don't work. Have about 200 templates, many that were "production" templates, that is they would do 7 problems per template. In some the output could be linked to another template for a specific task. Example is a plywood shear wall template that would size the plywood or particle board or sheet rock and the end pieces. Then the next template would size the hold down fixture for uplift as well as the sill bolts for sliding. Each template had a current data base. Each template had sections for explanations of input and output and then there was a hidden column (L) that could be expanded that provided all of the documentation for printout to be submitted to the building department if they were requiring documentation for home grown spreadsheets. No data was hidden. All cells could be hand calc checked. These could be all fitted in one master spread sheet that had headers, date and time so one could keep track of the latest print out. One page of the master spreadsheet was an hyperlinked index. Practically eliminated hand written calcs - final version 1990). Developed versions for about 5 to 6 years before within my office of about max 15 engineers (ladies and gentlemen engineers). Serious development in 1990 - 1992. Had various data bases - steel, wood, connections, rebar, bolts, screws - ect. Then Windows and Excel came on the market and no one was interested in DOS, Lotus and our RCT program!
