Difference between rubber testing 1
SR71-110
12
Hi All,
I have a quick question regarding rubber testing.
Is it correct to compare Tear strength tests from ISO and ASTM between ISO 34-1 Method A and ASTMD624 Die C?
Are they the same?
Thank you :)
If you are making a contract, put the one which is more stringent.
I have used the ASTM one only, no idea about the other.
DHURJATI SEN
Kolkata, India
The strength tests should compare fairly well.
But don't try to compare other tests such as tearing.
