JStructsteel
- Aug 22, 2002
- 1,460
I may have talked about this before, but I have a job where the rear wall is a 3-wythe brick wall. Its in bad shape. The plan is to rebuild with 3 wythes up to the second floor, then 2x6's with a veneer.
At the door on the 2nd floor, there will be a landing. I am going to kick it down to the wall below. I am trying to come up with the best connection. I show a WT they embed when rebuilding, but having second thoughts due to water infiltration.
Another idea would be to use a thru bolt plate, with a angle or something to catch the 4x4 coming down. (alternate is to use steel angle to kick down)
Any better thoughts how to support this landing. About 9 feet long. Not a huge amount of load.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1678845965/tips/Landing_Support_i1t0b8.pdf[/url]
