Which American code contains fire resistance of materials?
tmgczb
CN
Like sandwich panel, 100mm THK, filled with mineral wool, 100kg/m3, the fire resistance is 0.8 hour.
Similarly, for clay brick wall, 240mm THK, considering plaster at both sides, fire resistance is 8 hours.
There is mention of materials of construction in the NFPA codes.
That would be crazy to include in a code, since new products are constantly created. The NFPA is concerned about the final result, regardless of material. It's up to the manufacturer to test and certify that their material meets the NFPA requirements. When I got my house reroofed, every material I looked at would have a fire resistance rating for embers landing on the roof, etc.
TTFN (ta ta for now)
Building codes specify "required fire protection rating".
A web search for fire rated assembly details will bring up construction details that have been tested by third party testing laboratories (UL and FM for example).
National Concrete Masonry Association FAQ 21-14 "What is the difference between fire resistance ratings for masonry assemblies obtained through IBC versus a listing service such as UL or FM?" attached
 https://files.engineering.com/getfile.aspx?folder=0b9b5a14-2581-442f-bcde-acb73dbdc5e2&file=FAQ_21-14.pdf
