Local language issue with NX2212
PSI-CAD
Computer
Feb 13, 2009
997
I have the following error in log file with NX2212
QT: Failed to read translation files for UGII_LANG=french
Everything is OK with older versions
any idea ?
TIA
Didier Psaltopoulos
They moved localizations into optional installation packages in one of the recent releases. Do a "Change" installation and check if you have the french one installed.
