Layer change Default
edmeister
Member
Jun 25, 2002
97
My recent peeve is when i change layers ..
I would prefer all the properties change to the same settings as the default layer setting ..
> presently when i change layers .. all that changes is the layer name with colour & other properties remaining the same as the selected line (color, scale .. etc. do not change)
- then i have to go thru all the properties and change accordingly ..
When I select layer "hidden wall" to to have it auto change all properties automatically to the hidden-wall default values ..
(ie: line type hidden, colour-default, scale-default .. etc)
- thus if i have a need to change the colour; after i selected the layer type; i go back & change the colour property.
I do not understand the what the advantage is to the present system where only the layer name changes ....
