Unknow profile shift coefficient
lucadueberto
3
hi to all
i have a question
i have an unknow gear: note number of teeth, int and ext diameter and module i need to know the shift coefficient
any ideas? i try but i dont't know any formula ..
thank you very much. Lucia
Lucia
best bet would be to have a gear shop reverse engineer for a cost. the have unknown gear program that will make short work of it.
profile shift or any thing else, also there are cheap gear programs, very reasonable
Thank you for the reply but i would try to calculate the shift coefficient using a formula
Using a math formula with excell for example
Someone knew how to calculate? Thank you
Lucia
Hi Lucia, first what makes you think there is a shift Coeficient, secondly why can't they be standard gears.
